CONSEIL ACHAT G55VW BATTERY NOT CHARGING PROBLEM
N75SF
N75SF
Orange lamp for batter charging is on all the time.
In windows battery G55vw icon : 46% available(plugged in, charging)
When i try charging with laptop turned off, same thing, no charge, orange lamp on.
Laptop working normal on full stress when is on charger, and on battery.
So, i can't charge my battery. Do you think is problem with battery or motherboard????
Saying Hello and Thank you is not hard to say when you first come to a place to ask for help.
Are you battery resseller ?
Hi
more likely the battery, as it is 3 years old now.
Try to buy a new battery and check again.
You will have to do a calibration (several complete charge/discharge) in order for Windows to calculate an accurate charge level.
20.00 €
    <font color="red"><b>Asus Bot</b></font> Asus Bot: Epouloum a ouvert une nouvelle discussion : Mot de passe non reconnu dans la section BIOS : Mot...
