Model G2P
G2P
En résumé 17.0" et ATI Mobility Readeon X1700
Dans le détail les combinaisons ci-dessous.
Intel® Core™2 Duo Processor T7600/T7400/T7200/T5600/T5500, 1.66~2.33GHz, FSB: 667MHz, 4MB/2MB L2 Cache
Microsoft® Windows® XP Professional, Microsoft® Windows® XP Home, Microsoft® Windows® XP Media Centre Edition
Mobile Intel® 945 PM Express Chipset + ICH7M
DDR2 533/667 MHz SDRAM, , expansion up to 2GB SDRAM
17.0" WXGA+ (1440x900) ColorShine TFT-LCD,Asus Splendid Video Intelligent Technology
ASUS Direct Messenger for In-Game system information
ATI Mobility Readeon X1700 GPU512 MB Physical VRAM
2.5" 9.5mm HDD , 80/100/120/160 GB (5400rpm)
DVD Super Multi driveDVD Super Multi Light Scribe drive
MMC, SD, MS, MS-Pro
Integrated Intel® High Definition Audio chip (Azalia) compliant MDC fax/modem and 10/100/1000 Base T. Integrated 802.11a/b/g.Built-in Bluetooth™ V2.0+EDR(optional).
1.3M Megabyte Pixels
Power-on/SuspendBattery Charging/full/lowStorage device accessCapital / Number LockWireless indicatorBluetooth on status (optional feature)
1 x Express card1 x Microphone-in jack 1 x Headphone-out jack (S/PDIF)1 x VGA port 1 x DVI-D5 x USB 2.0 ports1 x IEEE 1394 port1 x RJ11 Modem jack for phone line1 x RJ45 LAN Jack for LAN insert1 x Wireless ON/OFF switch (Wireless Console to control Wireless/BT)1 x SIR1 x CIR1 x TV-out(S-Video)1 x AV-in port (Optional)
Function Keys: Fn+F1 suspend switch Fn+F2 Wireless control Fn+F5 Brightness down Fn+F6 Brightness up Fn+F7 LCD on/off Fn+F8 LCD/CRT/TV-out switch display Fn+F10 Volume on/mute Fn+F11 Volume down Fn+F12 Volume up Fn+Ins Numeric Key Pad on/off Fn+Del Scroll Lock on/off
Built-in Intel® High Definition Audio ( Azalia ) compliant audio chip, Built-in speaker and microphone
Standard Keyboard with 88 keys
Li-Ion 71WHrs (8 cells: 4800mAh, 4S2P)charging time: 4.5hrs/2.5hrs (System On/ Off) to 95%
Output: 19V DC, 4.74A, 90WInput: 100— 240V AC, 50/60Hz universal
410.6mm * 315.6mm * 46.6 mm(W x D x H)4.4 Kg (8-cell)
Booting / HDD User Password Protection and security lockKensington lock hole
Optical Gaming MouseGaming Backpack
ASUSDVD XP 6.0Power Director V3.0 DEMedi@Show V2.0 SE
Symantec's Norton™ Internet Security 2005 Adobe Acrobat Reader 7.0NERO Express V6.0
ASUS Live UpdateASUS SplendidASUS Life Frame 2ASUS Power4 Gear+ASUS Direct ConsoleASUS Wireless ConsoleASUS Power4 Phone
2-year limited global hardware warranty1-year battery pack warrantyOn-line problem resolution through web interface (BIOS, Driver update)OS (Microsoft Windows XP) install/uninstall consultation Bundled software install/uninstall consultationASUS software supporting
où trouver tous les drivers pour un G2P Series avec XP ? Un cd fourni avec le portable contenant tous les drivers n'est dispo que pour Vista.
Pouvez vous m'aider svp ?
Merci.
David
Je viens d'acquérir l'asus G2pc 7r004c car le vendeur ma assuré que je pourrais jouer a donfff sur tous les meilleur jeux actuellement, mais une fois les jeux installer sur le pc ils n'y en a pas un qui peut tourner en haut résolution : Quake 4 (je ne peut jouer qu'avec le minimum vital, résolution mini..)
Far cry : idem au mini si non je plante le jeu comme Quake 4, starwars battle front tout pareille!!!!
Alors y a t'il des réglage ou pour se genre de jeux c'est la pas la peine d'insister?
(J’ai installer le dernier pilote ati et re-tout pareille!!?)
Une âme charitable peut-elle m'aiguiller avent que je le retourne au mag... Merci a tous!!!
à priori tu as forcément un big problème car comme toi j'ai un G2PC mais en windows xp media center car tu dis que FAR CRY tu ne peux y jouer qu'au mini !!!
j'ai installé FAR CRY sur mon G2, j'ai même activé le HDR et l'AA par des modifs et en plus j'ai installé la version 64bits gràce à un pack trainant sur le net permettant de modifier le version pour OS 32bits en version 64bits (çà demande énormément sur la CG, mon ancien PC ne le faisait pas tourner correctement fluide).
Bref il tourne en TRES ELEVE en ayant pris soins de vérifier toutes les options et de les mettre au taquet et le jeu est hyper fluide !!!
Par contre n'aimant le 16/10 je joue en 4/3 en 1024x768 mais çà change rien en 16/10 à part la déformation des images (écrasement par rapport au 4/3) que j'aime pas !!!
Pour te donner plus cordes à ton arc pour aller voir ou tu l'a acheté, FEAR tourne très fluide en config auto (des trucs en moyen au lieu de max) à une moyenne de 50 fps enfin dans le genre, OBLIVION tout au max HDR compris, GOTHIC3 en ELEVE très fluide.
Maintenant demande l'avis de ceux qui l'ont sous VISTA car je te donne mes infos d'un XP MEDIA CENTER qui bouffe moins qu'un VISTA
Mais même sous VISTA si il devrait y avoir une légère perte de performance, ils devraient tourner très bien !!! il doit y avoir un défaut sur ta carte graphique car les symptomes tels que tu les décrits sont ceux d'une personne voulant faire tourner un jeux sur une CG à mémoire partagée sans mémoire propre alors que ta carte possède normalement 512Mo DDR2 dédiés et éventuellement 512Mo de plus en mémoire partagée !!!
merci de ta réponce, oui en éffet je tourne sous vista et peut tu me donner toute t'est modif (si tu veut bien ;-) .
pour le configure au petits oignons!!!
il n'y a aucunes manip ou modifs à faire !!! Far Cry est sûrement incompatible Vista !!!
je l'ai configuré en TRES ELEVE en 1024x768 c'est tout.
Essai d'autres jeux car tous mes jeux tournent correct dessus comme FEAR OBLIVION GOTHIC3 ARMA ARMED ASSAULT TOMB RADER LEGEND etc...
D'ailleurs pour s'en convaincre va sur ce lien et choisi le jeu que tu veux il va te donner comment il fonctionnera et pour tous les jeux que je viens de te citer il me dit qu'ils tourneront dans d'excellentes conditions ce qui s'avère être vrai
le site
Bonjour à vous les amis !!!
Je suis interessé par tes remarques, antpavtoto car moi aussi possesseur du G2PC-7R001M acheté cet hiver.
Je suis très perplexe car je me trouve dans la situation présente concernant les jeux:
(je précise que j'ai mon PC "tel quel", je n'ai rien bidouillé du tout ou cherché à améliorer quoi que ce soit.)
Je suis comme toi sous WinXP MCE 2005 et non sous Vista:
J'ai acheté HALF LIFE 2, tourne nickel a fond y compris avec les textures très hautes résolutions de FakeFactory (les connaisseurs comprendront).
son extension Lost coast tourne hyper fluide même si Steam réclame un PC à 3GHZ
Resident evil 4 tourne nickel, très fluide
Fable, lost chapter, obligé de descendre un peu les options quand même mais très fluide.
Par contre, je viens d'acheter Oblivion et là, grosse déception, limite jouable, obligé de descendre la résolution, les effets etc... enfin bref tout ce qui fait que le jeu est supposé être beau.
Donc là je ne comprend plus ??? Si le problème était matériel (au niveau de la carte graphique) je devrais avoir des perfs minables avec Half Life 2 et autres, ce qui n'est pas le cas, bien au contraire, mais Oblivion, c'est très très très décevant !!!!
Reste le pilote, au fait quelqu'un sait comment est géré l'Hyper memory avec cette carte ? (X1700)
Mon pilote est la version 6.8 d'ATI et c'est pas facile d'obtenir une quelconque info sur la compatibilité de pilotes plus récents.
Par exemple le site d'ATI ne prend pas en compte apparemment notre mobility X1700 ?????
J'attend vos commentaires avec impatience les amis !!
trefuilngid
Michel
Je n'arrive plus à faire fonctionner le Media Center d'un Windows XP.
Il se lance et s'affiche correctement, mais lorsque je clique sur l'icône de l'écran dans 'ma TV - TV en direct' rien ne se passe.
Par contre tout semble correct pour les autres fonctions, de la programmation à regarder une ancienne émission enregistrée.
Qui aurait un conseil à me donner ?
(G2p acheté fin décembre)
Problème résolu ! A tous, c'était ici :
"Mise à jour cumulative" :
https://www.microsoft.com/downloads/details.aspx?FamilyID=e5daf37e-e243-4410-b(...)
Mais ce fut difficile à trouver !!!
Sur un forum de 01.net comme chez Asus "on" me conseillait de reformater ma partition. Le reformatage est souvent le conseil de l'incompétence ; la preuve, sans être un professionnel de l'informatique (mais pas un débutant), je me suis débrouillé et ai trouvé par moi-même.
Nouvelle modification !
En vérifiant mon lien vers Microsoft, on n'accède pas à la bonne page. Le fichier à récupérer est celui ci :
Office2003SP3-KB923618-FullFile-FRA.exe
et il fait 132 Mo.
Je vous souhaite de le trouver plus facilement que moi... si vous en avez besoin.
NimRod, Je faisais tourner OBLIVION avec les QARL TEXTURES PACK 3 pour les connaisseurs (supposé mettre à genoux les CG faibles) et c'était fluide dans les 22 fps dehors et les 35 fps en intérieur par contre il faut rester en 1024x768 (c'est impératif), il faut virer les ombres (sauf les canopés celles des arbres, et laisser les sliders d'ombres tel quel, de plus laisser les réglagles tel quel dans les options avec les sliders, et mettre à elevé le sang et l'eau.
Par contre hyper important pour ce jeux qui travaille en STREAMING (chergement des données sur le disque dur à la volée) c'est désactiver tous les programmes résidents comme essentiellement l'antivirus qui à chaque accès de donnée va scanner et faire perdre du temps !!!
sinon sur mon G2 j'avais mis les catalystes 7.5 trouvés ici (faut être persévérant car le site est souvent saturé et en maintenance mais ce sont les meilleurs drivers que j'ai trouvé pour ce G2)
https://www.asustreiber.de/download.php?view.554
PS: je ne peux te donner que des infos de mémoire car j'ai refilé cet excellent G2 dans la famille car on m'a offert un superbe DELL XPS !!!
40.00 €
