HELP ! [ASUS TUF gaming FX705DT 2019] probleme avec le SVM mode
cdumdum
TUF gaming FX705DT
Fnac
windows 11
Bonjour a tous/
Le probleme : quand mon ordinateur a le mode svm activé et uam en auto dans l'UEFI, windows 11 ne demarre pas.
en analysant les dump suite au BSOD je m'apercois que c'est le driver amdgpio2.sys qui est en cause. auriez vous une solution autre que de desactiver le mode SVM ?
specification du driver amdgpio2.sys : date 11/03/2020, version : 2.2.0.130
analyse du dump avec windbg :
*                        Bugcheck Analysis                                    *
DPC_WATCHDOG_VIOLATION (133)
The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
or above.
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
    DISPATCH_LEVEL or above.
Arg2: 0000000000001e00, The watchdog period (in ticks).
Arg3: fffff8009bbc43b0, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
    additional information regarding the cumulative timeout
Arg4: 0000000000000000
Debugging Details:
Unable to load image \SystemRoot\System32\drivers\amdgpio2.sys, Win32 error 0n2
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: TickPeriods                                   ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 3718
    Key  : Analysis.Elapsed.mSec
    Value: 17597
    Key  : Analysis.IO.Other.Mb
    Value: 16
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 35
    Key  : Analysis.Init.CPU.mSec
    Value: 10687
    Key  : Analysis.Init.Elapsed.mSec
    Value: 627196
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 117
    Key  : Bugcheck.Code.KiBugCheckData
    Value: 0x133
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x133
    Key  : Dump.Attributes.AsUlong
    Value: 21800
    Key  : Dump.Attributes.DiagDataWrittenToHeader
    Value: 1
    Key  : Dump.Attributes.ErrorCode
    Value: 0
    Key  : Dump.Attributes.LastLine
    Value: Dump completed successfully.
    Key  : Dump.Attributes.ProgressPercentage
    Value: 100
    Key  : Failure.Bucket
    Value: 0x133_ISR_amdgpio2!unknown_function
    Key  : Failure.Hash
    Value: {d434f6b1-29cd-b7b6-5f14-790f39050aff}
    Key  : Hypervisor.Enlightenments.ValueHex
    Value: 749fcf96
    Key  : Hypervisor.Flags.AnyHypervisorPresent
    Value: 1
    Key  : Hypervisor.Flags.ApicEnlightened
    Value: 1
    Key  : Hypervisor.Flags.ApicVirtualizationAvailable
    Value: 0
    Key  : Hypervisor.Flags.AsyncMemoryHint
    Value: 0
    Key  : Hypervisor.Flags.CoreSchedulerRequested
    Value: 0
    Key  : Hypervisor.Flags.CpuManager
    Value: 1
    Key  : Hypervisor.Flags.DeprecateAutoEoi
    Value: 0
    Key  : Hypervisor.Flags.DynamicCpuDisabled
    Value: 1
    Key  : Hypervisor.Flags.Epf
    Value: 0
    Key  : Hypervisor.Flags.ExtendedProcessorMasks
    Value: 1
    Key  : Hypervisor.Flags.HardwareMbecAvailable
    Value: 0
    Key  : Hypervisor.Flags.MaxBankNumber
    Value: 0
    Key  : Hypervisor.Flags.MemoryZeroingControl
    Value: 0
    Key  : Hypervisor.Flags.NoExtendedRangeFlush
    Value: 0
    Key  : Hypervisor.Flags.NoNonArchCoreSharing
    Value: 1
    Key  : Hypervisor.Flags.Phase0InitDone
    Value: 1
    Key  : Hypervisor.Flags.PowerSchedulerQos
    Value: 0
    Key  : Hypervisor.Flags.RootScheduler
    Value: 0
    Key  : Hypervisor.Flags.SynicAvailable
    Value: 1
    Key  : Hypervisor.Flags.UseQpcBias
    Value: 0
    Key  : Hypervisor.Flags.Value
    Value: 38277359
    Key  : Hypervisor.Flags.ValueHex
    Value: 24810ef
    Key  : Hypervisor.Flags.VpAssistPage
    Value: 1
    Key  : Hypervisor.Flags.VsmAvailable
    Value: 1
    Key  : Hypervisor.RootFlags.AccessStats
    Value: 1
    Key  : Hypervisor.RootFlags.CrashdumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.CreateVirtualProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.DisableHyperthreading
    Value: 0
    Key  : Hypervisor.RootFlags.HostTimelineSync
    Value: 1
    Key  : Hypervisor.RootFlags.HypervisorDebuggingEnabled
    Value: 0
    Key  : Hypervisor.RootFlags.IsHyperV
    Value: 1
    Key  : Hypervisor.RootFlags.LivedumpEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.MapDeviceInterrupt
    Value: 1
    Key  : Hypervisor.RootFlags.MceEnlightened
    Value: 1
    Key  : Hypervisor.RootFlags.Nested
    Value: 0
    Key  : Hypervisor.RootFlags.StartLogicalProcessor
    Value: 1
    Key  : Hypervisor.RootFlags.Value
    Value: 1015
    Key  : Hypervisor.RootFlags.ValueHex
    Value: 3f7
    Key  : SecureKernel.HalpHvciEnabled
    Value: 1
    Key  : WER.OS.Branch
    Value: ge_release
    Key  : WER.OS.Version
    Value: 10.0.26100.1
BUGCHECK_CODE:  133
BUGCHECK_P1: 1
BUGCHECK_P2: 1e00
BUGCHECK_P3: fffff8009bbc43b0
BUGCHECK_P4: 0
FILE_IN_CAB:  MEMORY.DMP
TAG_NOT_DEFINED_202b:  *** Unknown TAG in analysis list 202b
DUMP_FILE_ATTRIBUTES: 0x21800
DPC_TIMEOUT_TYPE:  DPC_QUEUE_EXECUTION_TIMEOUT_EXCEEDED
TRAP_FRAME:  fffffd0c46141230 -- (.trap 0xfffffd0c46141230)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000000000000000 rbx=0000000000000000 rcx=ffffe08d8bbd61d0
rdx=ffffca8007ef3b20 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8003c56cc9c rsp=fffffd0c461413c8 rbp=0000000000000000
 r8=0000000000000000  r9=0000000000000005 r10=ffffe08d878e38f0
r11=fffffd0c46141320 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
CmBatt!CmBattGetBixData:
Page 12df51 not present in the dump file. Type ".hh dbgerr004" for details
fffff800`3c56cc9c ??              ???
Resetting default scope
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
PROCESS_NAME:  System
STACK_TEXT:
fffff800`2d7094f8 fffff800`9aef68d6     : 00000000`00000133 00000000`00000001 00000000`00001e00 fffff800`9bbc43b0 : nt!KeBugCheckEx
fffff800`2d709500 fffff800`9aef5e0a     : 00000000`00000000 ffff9401`2497ce00 fffff780`00000320 fffff800`291e6180 : nt!KeAccumulateTicks+0x596
fffff800`2d709570 fffff800`9aef5adc     : 00000000`00000008 00000000`00000001 00000000`00001334 fffff800`291e6180 : nt!KiUpdateRunTime+0xca
fffff800`2d709730 fffff800`9aef5099     : 00000000`0000000d fffff800`2d709a00 fffff800`291e6180 00000000`0000000f : nt!KiUpdateTime+0x37c
fffff800`2d7098f0 fffff800`9ae9f8ab     : fffff800`9ba10a70 00000000`00000000 fffff800`9ba10b20 fffff800`9bb8e2f0 : nt!KeClockInterruptNotify+0x2e9
fffff800`2d7099e0 fffff800`9b2a779e     : 00000000`0000000a fffff800`9ba10a70 00000044`24e8e0e5 00000000`4cd679d9 : nt!KiCallInterruptServiceRoutine+0x31b
fffff800`2d709a40 fffff800`9b2a7fac     : 00000000`00001332 fffff780`00000320 00000000`0000000d 00000000`00002038 : nt!KiInterruptSubDispatchNoLockNoEtw+0x4e
fffff800`2d709a90 fffff800`3c602935     : 00000000`000043f8 00000000`4cd5e780 fffff800`3c6055f0 fffff800`3c6055d0 : nt!KiInterruptDispatchNoLockNoEtw+0x3c
fffff800`2d709c20 fffff800`3c624ebf     : 00000000`00000000 ffffe08d`00000000 fffff800`0000000f fffff800`00000004 : amdgpio2+0x2935
fffff800`2d709ce0 fffff800`3c624177     : 00000000`00000002 00000000`00000014 00000000`00000001 00000000`00500a02 : msgpioclx!GpiopUpdateStatusAndMaskInformation+0x9b
fffff800`2d709d80 fffff800`3c623cc0     : 00000000`00000000 fffffd0c`00000000 00000000`00000000 00000000`00000005 : msgpioclx!GpiopServiceInterrupt+0xa3
fffff800`2d709e70 fffff800`3c62311a     : ffffe08d`8d3468e0 fffff800`291ef700 00000000`00000000 00000000`00000000 : msgpioclx!GpiopInterruptBankIsr+0x60
fffff800`2d709ea0 fffff800`2d09d886     : 00001f72`744fd238 00000000`4cd67986 0000003e`e9337f50 fffff800`9aef154f : msgpioclx!GpioClxEvtInterruptIsr+0x13a
fffff800`2d709ed0 fffff800`9ae9fac7     : 00000000`00000000 00000000`00000001 ffff9401`2497cdc0 fffff800`291e6180 : Wdf01000!FxInterrupt::_InterruptThunk+0x76 [minkernel\wdf\framework\shared\irphandlers\pnp\km\interruptobjectkm.cpp @ 374]
fffff800`2d709f10 fffff800`9b2a7580     : ffff9401`2497cdc8 ffff9401`2497cdc0 00000044`24e89f99 00000000`00000000 : nt!KiCallInterruptServiceRoutine+0x537
fffff800`2d709f70 fffff800`9b2a713c     : 00000000`4cd6784e fffffd0c`46140830 00000000`4cd678fc 0000003e`e9330e53 : nt!KiScanInterruptObjectList+0xa0
fffffd0c`461407b0 fffff800`2944001c     : fffff800`9b2a0c2b 00000000`00000000 fffffd0c`46140b70 00000000`00000000 : nt!KiChainedDispatch+0x3c
fffffd0c`46140948 fffff800`9b2a0c2b     : 00000000`00000000 fffffd0c`46140b70 00000000`00000000 00000000`00000000 : 0xfffff800`2944001c
fffffd0c`46140950 fffff800`9aedd477     : 00000000`054fe465 fffffd0c`46140b10 00000000`054fe50a 00000004`5969ecfc : nt!HvlSwitchToVsmVtl1+0xab
fffffd0c`46140a90 fffff800`9b0087cd     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!VslpEnterIumSecureMode+0x137
fffffd0c`46140b50 fffff800`9ae38b42     : 00000000`00000803 00000000`00000000 0a000001`2df51121 fffff800`9b2a715b : nt!VslSetPrivilegedPte+0x65
fffffd0c`46140c20 fffff800`9ae7c306     : fffff800`9ba37900 ffffdd7c`001e2b60 ffffbd00`0389df30 00000000`00000000 : nt!MiAllocateWsle+0x6f2
fffffd0c`46140cf0 fffff800`9ae7d158     : fffffd0c`46140fd0 00000000`0012df51 00000000`00000000 00000000`00000000 : nt!MiCompleteProtoPteFault+0x476
fffffd0c`46140de0 fffff800`9af12908     : ca800820`00000000 ffffca80`0820cba0 0a000001`2df51121 00000000`00000000 : nt!MiResolveTransitionFault+0x3d8
fffffd0c`46140ec0 fffff800`9af11f4d     : 00000000`00000000 00000000`00000000 fffffd0c`46140f88 fffff800`3c56cc9c : nt!MiResolveProtoPteFault+0x288
fffffd0c`46140f50 fffff800`9ae2964c     : ffffe08d`87100000 ffff8000`00000000 fffff800`3c56cc9c 0000007f`fffffff8 : nt!MiDispatchFault+0x1dd
fffffd0c`461410c0 fffff800`9b2b47cb     : 00000000`00000000 00001f80`00e500ef ffffe08d`8bbd61d0 6cd91cbc`69d20000 : nt!MmAccessFault+0x20c
fffffd0c`46141230 fffff800`3c56cc9c     : fffff800`3c56b49a ffffe08d`8bbd63a0 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x38b
fffffd0c`461413c8 fffff800`3c56b49a     : ffffe08d`8bbd63a0 00000000`00000000 00000000`00000000 00000000`00000000 : CmBatt!CmBattGetBixData
fffffd0c`461413d0 fffff800`3c56af4a     : ffffe08d`8bbd61d0 fffffd0c`46141540 fffffd0c`46141470 ffffe08d`8bbd6320 : CmBatt!CmBattVerifyStaticInfo+0x92
fffffd0c`46141410 fffff800`3c593473     : 00000000`00000000 ffffe08d`8bbcbbb0 00000000`00000000 00000000`00000000 : CmBatt!CmBattQueryTag+0x4a
fffffd0c`46141440 fffff800`3c595fb7     : fffffd0c`461416e0 fffff800`9ae403da ffffe08d`8ba81270 ffffe08d`874a4aa0 : BATTC!BattCCheckTagQueue+0xdf
fffffd0c`461415e0 fffff800`9aefcd92     : ffffe08d`8bbd2070 ffffe08d`8bbd2070 ffffe08d`87535400 ffffe08d`87535400 : BATTC!BattCWorkerThread+0xb17
fffffd0c`46141980 fffff800`9af21f43     : ffffe08d`8ba6f040 ffffe08d`874b4b20 fffff800`291e6100 ffffe08d`8ba6f040 : nt!IopProcessWorkItem+0x502
fffffd0c`46141a10 fffff800`9b0a3e1a     : ffffe08d`8ba6f040 ffffe08d`8ba6f040 fffff800`9af21da0 ffffe08d`874b4b20 : nt!ExpWorkerThread+0x1a3
fffffd0c`46141bf0 fffff800`9b2a6754     : fffff800`291e6180 ffffe08d`8ba6f040 fffff800`9b0a3dc0 ed897b28`e8ba19a5 : nt!PspSystemThreadStartup+0x5a
fffffd0c`46141c40 00000000`00000000     : fffffd0c`46142000 fffffd0c`4613c000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME:  amdgpio2+2935
MODULE_NAME: amdgpio2
IMAGE_NAME:  amdgpio2.sys
STACK_COMMAND:  .cxr; .ecxr ; kb
BUCKET_ID_FUNC_OFFSET:  2935
FAILURE_BUCKET_ID:  0x133_ISR_amdgpio2!unknown_function
OS_VERSION:  10.0.26100.1
BUILDLAB_STR:  ge_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {d434f6b1-29cd-b7b6-5f14-790f39050aff}
Followup:     MachineOwner
specifications de l'ordinateur :
Computer: ASUS TUF Gaming FX705DT_FX705DT
CPU: AMD Ryzen 5 3550H (Picasso, PCO-B1)
2100 MHz (21.00x100.0) @ 2445 MHz (24.50x99.8)
Motherboard: ASUS FX705DT
BIOS: FX705DT.316, 01/28/2021
Chipset: AMD Promontory/Bixby FCH
Memory: 8192 MBytes @ 1197 MHz, 17-17-17-39
- 8192 MB PC21300 DDR4 SDRAM - SK Hynix HMA81GS6JJR8N-VK
Graphics: NVIDIA GeForce GTX 1650 [ASUS]
NVIDIA GeForce GTX 1650, 4096 MB GDDR5 SDRAM
Graphics: AMD Radeon Vega 8 (Picasso) [ASUS]
AMD Radeon Vega 8, 2048 MB DDR4 SDRAM
Drive: CT1000BX500SSD1, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: Micron_2200V_MTFDHBA512TCK, 500.1 GB, NVMe
Sound: NVIDIA TU117 - High Definition Audio Controller
Sound: AMD Zen - Audio Processor - HD Audio Controller
Network: RealTek Semiconductor RTL8168/8111 PCI-E Gigabit Ethernet NIC
Network: Intel Wi-Fi 6E AX210 160MHz
OS: Microsoft Windows 11 Professional (x64) Build 26100.4202
Etes vous amené à utiliser des machines virtuelles sous Windows ?
Asus ne sait pas programmer.
On est en 2025 et asus n'a pas mis en place un correctif du pilote.
specification du driver amdgpio2.sys : date 11/03/2020, version : 2.2.0.130 et là on est en 2025 .
C'est lamentable.
Note: il y a un problème similaire via ce lien, la solution est de restreindre les processeurs amd mais la "panne" peut-être que ce problème sera la bonne solution.
Asus506 HELP ! ASUS TUF GAMING F15 FX506HE Support Windows 11 2
Sniperpav HELP ! [Asus tuf gaming F15 TUF566HM] Remplacement de touches Asus TUF 1
erik 95. HELP ! ASUS TUF GAMING F15 Support Réseau - WiFi 1
viloque HELP ! 21 ASUS TUF Gaming A17 TUF706ICB-HX092W Supprimer rétroéclairage Support Windows 11 6
PatA17 HELP ! ASUS TUF Gaming A17 FA706IU_FX706IU Le planificateur de tâches ne réveille pas le PC du mode veille Support Windows 10 2
ewen HELP ! Asus TUF Gaming F17 Support Réseau - WiFi 2
olivier52 HELP ! asus tuf gaming f7 fx706hc_tuf766hc Support Logiciel 0
JimRaynorLoveKirrigan HELP ! ASUS TUF Gaming F15 FX506HE-surchauffe CPU 80 degrés Support Windows 11 2
viloque HELP ! ASUS 2021 TUF Gaming A17 TUF706ICB-HX092W MAJ AMD adrenalin edition Support Windows 11 2
EagleDeath HELP ! ASUS TUF Gaming A17 Accessoires et Périphériques 7
P RESOLU ASUS TUF Gaming F15 FX506HE Asus TUF 6
Phil585 RESOLU ASUS Tuf Gaming A17 - bios en boucle au démarrage Asus A - TUF A 65
Quatremaille SAV Asus Tuf gaming A17 SAV, Droits et Garantie 2
LaBibs HELP ! Asus TUF Gaming A15 Asus A - TUF A 3
S RESOLU Asus TUF Gaming F17 (TUF706HEB) Asus TUF 7
S RESOLU ASUS TUF Gaming F15 FX506HC - Verrouillage touches fonctions Asus TUF 4
viloque RESOLU ASUS 2021 TUF Gaming A17 TUF706ICB-HX092W Asus A - TUF A 3
FoxTrot_Biotch HELP ! ASUS TUF Gaming A17 FA706ICB carte graphique inexistante Asus TUF 3
Azor HELP ! Asus tuf gaming F15 SAV, Droits et Garantie 14
Melda HELP ! Asus TUF Gaming FX504 - quel est cette piece ? Asus TUF 0
Max VH HELP ! ASUS TUF Gaming A15 FA506IU_TUF566IU Support Réseau - WiFi 3
ilyes HELP ! Asus tuf gaming FX705GM 8750h Support Windows 10 1
Sorawna HELP ! Asus Tuf Gaming A17- Asus A - TUF A 3
cara RESOLU asus gaming tuf F15-comment controller ses ventilateurs Support Windows 10 17
Sapperstein HELP ! ASUS TUF GAMING F15 FX506HCB + Ventilo montant en régime lors de l'ouverture du BIOS Asus TUF 3
Sapperstein RESOLU ASUS TUF GAMING F15 FX506HCB + "Aucun périphérique audio n'est installé" Asus TUF 2
Feloya HELP ! Asus tuf gaming f15 Asus E et F ou Vivobook E et F 1
mxlou01 HELP ! Asus Tuf Gaming F15 - Armory Crate Asus E et F ou Vivobook E et F 1
lea.vlln RESOLU Asus Tuf Gaming Message erreur démarrage pc Support Windows 10 13
Sniperpav HELP ! [Asus tuf gaming F15] question à propos de HW monitor Support Logiciel 15
Coldnight42 HELP ! Asus TUF505DV Ralentissement en gaming Asus TUF 3
antonin3101 RESOLU PC Portable Gamer ASUS TUF Gaming F15 installer sans windows 10 Support Windows 10 10
Lost HELP ! ASUS TUF Gaming VG24VQ Support Windows 10 5
MALAIZE rodolph RESOLU Asus tuf gaming a17 SAV, Droits et Garantie 5
