300 ]
1.Support the MEROM CPU for A7J project.
2. Fix bug that Merom CPU system will hang when boot from USB storage and install EMM386.exe.
3.Do not display "F2:Enter Setup ESC
opup Menu" during POST in Instant On mode for we do not allow user to Enter Setup Menu or Select Boot Device during POST of Instant On mode.
[ 209 ]
1.Fixed the System can't run into the S3 mode again after system resume from S3.
2.Enable the wireless console can disable the Wireless and Bluetooth item.
[ 208 ]
1.Update the Latest the new VGA
BIOS to improve the Panel EDID can’t detect issue. This is factory report problem.
2.Decrease the S3 resume time to meet the MDP request.
3.Update Yonah CPU MicroCode for D-0 Stepping.
[ 207 ]
1.Fixed the System can’t run into the C3 state when playing audio CD.
2.Fixed the system can’t power on when use the Celeron CPU.
3. Fixed the system hang with press plus or minus from boot device priority of setup menu.
4.Fixed the system will automatically restart by press remote controller power button
over two times. The correct behavior should shutdown.
5.Update the Latest the new VGA BIOS to improve the Panel EDID can’t detect issue.
[ 206 ]
First release
[ 205 ]
First release
