RESOLU x93 s CARTE WIFI UPGRADE ??
Bravo et merci pour la communauté de ce forum ;)
ce tweak a été relaté aussi dans ce post >> https://www.notebookforums.com/t/225429/broken-wireless-hardware-switch-fix et aussi ici >> https://www.amazon.co.uk/review/R1LV0YTVATLU21/ref=cm_cr_dp_title/279-7873417-0196661?ie=UTF8&ASIN=B008H0SHQE&channel=detail-glance&nodeID=340831031&store=computers en commentaire
This review is from: Intel Centrino Advanced-N 6235 Band 2X2 Bluetooth, 6235AN.HMWWB (Electronics)
I bought this to replace the cheap card supplied with my Toshiba A660-18n
I installed it, started up the laptop, but got an error message that the Radio was turned off.
after a lot of head scratching, useless trawling through User-group or faqs.
I finally found the solution.
to prevent the user upgrading the laptop wifi, Toshiba (And others) hobble your efforts by having the Bios turn off any but the supplied wifi card. before the operating system starts, so your wifi switch wont work, nor will the Press Fn plus F8 key method.
Finally I downloaded the Installation & Product manual.
The answer is to mask off Pin number 20 with insulating tape, this stops the Bios turning off Wifi
But if you want to use the Bluetooth option, you also need to mask off pin Number 51.
Before doing any of this, with your old wifi installed, download the drivers for the 6235 from Intel website
then with the 6235 installed, install its drivers. and everything works.
I am getting great speeds now, with excellent connection quality.
you will have to disconnect from the internet using the intel driver, but its a breeze to use.
also, on the A660-18n, the wifi led wont illuminate, but this does not matter because the intel driver software
clearly shows on the taskbar that wifi is on/off. plus, it lets you turn off the 6235 card.
an excellent product,
if you need to know,
turn the card over so the short lug is on your right, then going right to left, pin 20 is the second one in on the longer lug
------------!- ------ (Wifi !=pin 20). &. on the other side ------ ----------! (bluetooth != pin 51)
so if you dont mind a little diy this card is excellent,
also the Intel software (Driver download). lets you really adjust this card to optimal settings if you choose the
administrator install option, as against end user. its simple, when you run the downloaded file just select the administrator option.
hope this helps
Je serai néanmoins curieux de savoir si tu t'en serais sorti sous ubuntu, sans passer par la case démontage....
stormrider
X93 S YZ158V
intel i5
1 To
4GO
1080 / 18 pouces
windows 8
Bon, pour commencer à changer une carte wifi sur le X93S (je pense que ce sera pareil pour la serie K93SM &K93SV, il faut etre sur de son format ,qui est le suivant :
half (demie) mini PCIE , elle est constitué de 2 antennes , ya le choix chez plusieurs fabriquants ,atheros, intel,realtek etc... ; celle est une intel centrino advanced N 3265 elle fait le bluetooth et le WIDI (compatible suivant la génération du processeur)
On commence donc par enlever le capot arrière retenu par deux visses de chaque coté
puis on pousse vers l’arrière le capot (on fait coulisser si vous preferez ) en se servant des patins antidérapants
On a donc acces a certains éléments hardware (disque dur, slot RAM,emplacement SSD,batterie etc..)
pour libérer la carte wifi il vous faudra donc enlever le clavier , pour cela il faudra dévisser 2 visses et pousser dans un petit renfoncement une languette qui aura pour effet de soulever le clavier (fleche bleue),et de le déclipser ça vient tout seul comme du beurre :good:
Elle est maintenue par 2 visses , il faut enlever les 2 antennes, en faisant levier par l’arrière tout doucement c'est juste enfiché .
Donc pour mon modèle la radio de la carte ne s’allumait pas ,carte reconnue dans le gestionnaire de periph , le plus souvent sur les mini PCIE c'est la pin 20 le soucis (elle permet l’allumage de la radio) suivant qu'elle soit compatible à 100% avec votre pc portable sur certains aucun soucis ca marche direct d'autres non , donc d'ou cette modif.
Il faudra donc masqué cette pin ,alors là c'est un peu chirurgical :cry3: il faut couper de fines bandelettes de scotch isolant, et placer sur la pin (donc tournevis de précision, pinces à épiler etc..)pour appliquer cette fine bande
La pin 20 est donc du coté ou il y a pas les antennes ,donc la deuxieme à partir de la droite sur le coté le plus long
donc moi je prend une planche a sauciflard :ah: , un cutter ,et donc je coupe le scotch en fine lamelle ,et biensur pour faire bien droit une règle ou équerre ,ca fonctionne assez bien faut bien appuyer ,puis couper à la longueur voulu.
Pour remettre en place la carte il faut y aller délicatement, sur la carte atheros (origine) l'antenne noir était enfichée sur le "main" et l'antenne blanche sur "aux" ,sur l'intel c'est l'inverse donc l'antenne noir sera sur "aux" et la blanche sur "main" , perso je ne vois pas ce que ca change pour avoir tester dans les deux sens .
Voici un doc pdf sur les carte mini pcie intel
https://ftp.compal.com/Download/NB/Temp/POS/BOM Spec/Spec List/WLAN Card/2012_Intel_Centrino_Wireless_Products_Hardware_Specification_EPS_Rev2.2.pdf
a partir de la page 48 commencent les infos et schéma de la carte je me suis servi de ça pour trouver mes pin ,et donc il semblerais que l'antenne aux servirait pour le bluetooth
Une fois la carte remise dans son logement on refait l'operation inverse, de remontage, et on redémarre l'engin ,et là on constate ben !!!rien lol donc pour moi windows 8 je dois aller dans paramètres et tout en bas (barre des charmes) "modifier les paramètres du pc"; puis enfin l'onglet "sans fil" et activer le wifi et enfin cela fonctionne
Voici les drivers intel c'est mieux de prendre les plus récents même si ceux contenu dans windows 8 fonctionnent
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3315&DwnldID=22741&ProductFamily=Sans-fil&ProductLine=Produits+Wi-Fi+Intel®+Centrino®&ProductProduct=Intel®+Centrino®+Advanced-N+6230&lang=fra
attention a la version regarder bien si vous avez du 32 ou 64 bits
nom du fichier :
Wireless_15.8.0_e64.exe
à l'install faites, installation personnalisée ,et cocher le tout pour les logiciels intel très pratique on peut désactiver le wifi ,ils nous donnent les infos dans la barre des taches qu'on avaient plus avec windows 8
Voilà pour mon cas ,je suis satisfait, le seul pc portable qui n'arrivait pas a faire sortir mes points d’accès de veille (économie d'energie , green etc...) cela fonctionne a merveille maintenant le point d’accès se fait réveiller comme il se doit plus vite mem que les autres ordi de la maison ,avant c’était "niet " , nada ,ou alors fallait d'abord qu'un autre périphérique le sorte de veille pour que mon asus veuille bien se connecter et me donner l'acces au net ,là plus de soucis
Si ya d'autres questions ou si j'ai oublié un truc n’hésitez pas
stormrider
X93 S YZ158V
intel i5
1 To
4GO
1080 / 18 pouces
windows 8
j'oubliais pour le bluetooth
même opération sur la carte wifi , mais faut masquer la pin 51
le logo bleu du bluetooth apparaitra directement dans la zone de notification
voici la pin 51 ,coté antenne cette fois ci
c'est la toute premiere pin ,on pourra alors faire une bande de scotch plus large
desolé pour les photos il faisait deja nuit
stormrider
X93 S YZ158V
intel i5
1 To
4GO
1080 / 18 pouces
windows 8
Donc c’est resolu pour moi , même avec un jeu crysis 3 qui fait bien chauffer l'ensemble ca n'as pas bronché
STC111
K93SV
Intel I7 2670QM
SSD 256 GO + HD 1TO
12 GO DDR3
1980X1080
W10
Cela fonctionne aussi avec une carte Intel Wifi 6 AX 200 sur un K93SV
Par contre la connexion wifi ne se fait qu'en Wifi 5 et non en wifi 6.
Bizarre.
Bonsoir STC111 STC111
Bizarre.
Le dernier message datant de 2013, vous aurez peu de réponses
Ouvrez votre propre sujet si vous avez une question :
Je ferme celui ci.
H Changement carte graphique ASUS X93S Asus X 1
C RESOLU [X93S]Problème carte graphique GT540M sur GTA IV Asus X 2
M HELP ! RA[modèle: X93SV Windows10] Rajout de RAM Asus X 6
retraitéEric HELP ! asus x93s wifi pas reconnu Asus X 0
Teddydu55 HELP ! Asus X93S Ne démarre plus Asus X 6
SejAC RESOLU X93SV-YZ102V - Installation d'un SSD Asus X 6
carpeur18 RESOLU X93SV-YZ100V Asus X 2
Wrecka6 HELP ! X93SV-YZ145V - conseils upgrade ? Asus X 9
jo79 RESOLU X93S Asus X 4
olivier59 HELP ! asus X73SJ-TY012V et X93SM-YZ179v Asus X 1
olivier59 HELP ! X93SM-YZ19V Asus X 1
cyrillus1869 HELP ! X93S Asus X 4
A RESOLU x93s pave tactile Asus X 5
Marin5966 X93S plus accès au bios Asus X 1
J RESOLU X93S - la camera ne fonctionne plus Asus X 7
GérardCC29900 HELP ! X93SV Affichage alterné Asus X 7
T HELP ! X93SV-arrèt si pas branché sur secteur Asus X 1
P RESOLU X93SM-YZ092V : Problème Controleur audio & pilotes Asus X 1
CHRI5413 HELP ! bios clé usb-X93SM Asus X 84
Z RESOLU X93SM-YZ179V : Problème Controleur audio & pilotes Asus X 30
T HELP ! Demontage du x93sv pour nettoyage ventilateur Asus X 7
Dr_Hannibal HELP ! Problème écran Asus x93sm Asus X 4
_bsg_ HELP ! Recherche référence pièce Asus X93SM Asus X 6
L HELP ! X93S ne s'allume plus Asus X 6
N RESOLU Bouton power x93s HS Asus X 6
L HELP ! Fichier pintlgb.imd corrompu Asus X93s Asus X 21
jackjean RESOLU Recherche Fichier dump BIOS X93SV Asus X 8
K VENDU X93SV-YZ101V (K93) pour pièces Vente 0
K RESOLU X93S sans rescue date malgré un clear CMOS Asus X 14
B RESOLU asus X93S Asus X 7
boel HELP ! pilote reseau pour x93 sv Support Windows 7 2
S HELP ! Restauration X93SM Asus X 17
M HELP ! Nettoyer ventilateur d'un asus X93S Asus X 10
D HELP ! .X93SM bios 209. Asus X 2
R HELP ! .Problème bouton power x93sv. Asus X 30
L .ajouter de la ram sur asus X93sm S YZ158V. Asus X 1
R RESOLU problème batterie sur asus X93S Asus X 3
M HELP ! Upgrade X93SV Asus X 2
Gusty RESOLU Problème de Batterie avec un ASUS X93S Asus X 3
lool74 HELP ! Asus X93SV bloque parfois au demarrage ou s'eteint Asus X 6
L HELP ! pb mise a jour ndivia sur x93s Asus X 1
L HELP ! pas de son en hdmi sur mon x93s Asus X 1
J HELP ! Problème Asus X93S Asus X 2
N HELP ! Sata 3 sur asus x93sv Asus X 1
L HELP ! Asus X93SM ne demarre pas Asus X 7
M HELP ! lecteur de disque interne X93S Asus X 10
M HELP ! X93S Boot SSD position 2 Asus X 10
M HELP ! X93S Problème plasturgie Asus X 5
G poblème avec prise USB sur un X93SV-YZ105V Asus X 3
